Results 1 to 9 of 9
Thread: Fox Speedway's Hardbody Enduro
    Nov 2004
    plainfield illinois
    We had a nice turnout for Fox's 1st hardbody enduro with a total of 9 teams . We started the day off at 11:30 with each team qualifying for lane choice and at 12:00 sharp we started the race. We ran 15min. heats with a 1 1/2 min. lane change. Wow what a great time we had as there were a limited amount of track calls and crashes. I think at the end of the race there were maybe 3 cars missing parts. With all the good clean racing the race was over by 2:35. Thanks to everyone who participated and to Doug and Brian for a really well run enduro.
    Here's the results... Congratulations Team Fox!
    TEAM
    1. FOX......................................1094
    2. BOSTROM/PIPCHOCK............1061
    3. DZ/OAKS...............................1054
    4. WARRIOR...............................1051
    5. VOSTRY..................................1048
    6. GENERAL LEE.........................1009
    7. WHOHAHA...............................982
    8. E MOTORSPORTS.....................968
    9 HOOTERS..................................858
    TEAM FOX
    TEAM BOSTROM/PIPCHOCK
    TEAM DZ/OAKS
    TEAM WARRIOR
    TEAM VOSTRY
    TEAM GENERAL LEE
    TEAM WHOHAHA
    TEAM E MOTORSPORTS
    TEAM HOOTERS
    KEVIN
    Nov 2004
    plainfield illinois
    PICS OF CARS
    I WISH I COULD OF TAKEN SOME PICS OF THE RACE BUT WAS SORT OF BUSY RACING. HERE'S SOME CAR PICS
    TEAM WARRIOR'S CAR
    TEAM FOX
    HOPE YOU ENJOY PICS, KEVIN
    Nov 2004
    plainfield illinois
    attitude is everything!
    Bob, are you taking orders for your shirt? I know 8 teams that may be interested!
    Kevin
    Palatine, IL
    Looks like fun.
    Next time
    Tim
    Jun 2003
    Sweet looking cars. If you got any more pix, I'd love to see them.
    These cars were straight up ProTrack things with hardbodies?
    Durl
    Nov 2004
    plainfield illinois
    Durl, here's the rules we used for the enduro along with some nice pics of the hardbodies that are raced on the fri. night program.
    BODIES: American production cars from 1950 up with a minimum of 7 7/8" bumper to bumper. (55' chevys, ford fairlanes, station wagons, etc.) All cars must be decorated with three numbers,and a 3- dimensional interior that is lexan or plastic type. Cars must have the original kit winsheild,and a rear window that may be lexan. All cars must have front and rear bumpers at the start of the race. If a car is damaged so badly that the chassis or gears are exposed it must be repaired or you will be black flagged. Otherwise, the windows and bumpers may be lost due to wrecks and cars may continue to race. Cars may be lowered to the doorline,or 1 7/8" min roof height.
    4.5" FCR chassis with no modifications(other than the monting brackets may be moved inward for narrow body types. white guide flag only 1/8 axles front and rear. Chassis may be reinforced at the front and rear uprights with wire or brass tube.
    PARMA sealed 501 motor (brushes and springs may be changed)
    9 tooth pinion (steel is ok)
    Any pink Parma crown gear 48 pitch.
    Any lead wires with clips
    Any brass axle spacers.
    Velcro mounting only
    TIRES: PARMA FCR tires or Daytona Protrack tires with 13/16 fronts. 1/16 clearance under the car including the gear. ALL tires must have original white letters at tech.
    If it is not listed here, its not legal.
    Kevin
    Plainfield, Il
    I want to send my thanks out to Doug and Brian at Fox Speedway for a fine, well run Enduro yesterday. Thanks also goes out to Kevin Vostry for the excellent pictures of the teams, cars, and racing action.
    I know Team Fox had a good time and everyone else seemed to enjoy the action and socializing. Brian stated yesterday he intended to try to do this once a month so opportunities are coming for those who didn't make it this time.
    Just for the record I am the Team Fox guy who is follically challenged.
    Jon W.
    Chicago 'burbs
    Rules and what not
    People were requesting rules this past weekend for the hard body cars and we were out of printed copies. So, here are the rules for everything we race. (some classes we do not race any more or time slots have changed)- Brian
    FOX SPEEDWAY GENERAL RACE RULES
    1. Stamped steel cars must have .062” rear clearance at all times
    2. Spring steel cars must have .032” clearance at initial tech.
    3. All cars may be no wider than 3 Ό”
    4. Cars must have 1/2” or 5/8” fronts either plastic or o-ring type unless otherwise noted.
    5. Must have at least 3 cars to conduct a race
    6. All cars must tech to race. No work after tech.
    7. Tech opens 15 minutes before a race and the race starts promptly after tech is closed. There will be no waiting for any driver(s).
    8. There will be a claimer on the first place motor, any racer can buy
    the first place motor to prevent tampering with sealed motors. Motor
    brushes and springs may be changed, but no hardware
    9. Falcons have a $9 claimer, $13 for 16D’s, $14 for super 16D.
    10. All cars must have three numbers, a fully detailed lexan or plastic driver figure, and have font wheel wells masked or cut out.
    11. There are no “LOOP HOLES” in these rules. All decisions made by any tech director are final.
    PROPOSED RACE SCHEDULE FOR 2005/2006 season
    • Wednesday 7:00 pm Vintage Le Mans/Can AM 4”
    Parma sealed 16d, Pro Slot sealed 16d, Falcon or S7 Mini motor
    Any commercially available stamped chassis (reversed pans allowed)
    Open cockpit cars with separate interiors must have the window(s) cut at the cut line of the original car.
    Vintage Jk or Alpha bodies pre 1975
    48 or 64 pitch
    • Wednesday 8:00 pm Street stock, Tuner 4”
    Same motor and chassis rule as above
    Any non high down force street legal body
    • Friday 7:00pm 4” MILLENIUM
    Week 1 JK MILLENIUM CHASSIS ONLY
    Falcon motors
    No modifications to the chassis
    JK Daytona Prototype bodies only
    Week 2 JK Super trucks
    JK Super truck chassis only
    Parma sealed super 16 d only
    1/8” axle 48 pitch only
    1” tall fronts
    No interior required for this class only
    • Friday 8:00pm 4.5” FCR HARDBODY
    FCR RULES APPLY (they come with the car)
    May change lead wires, guide nut, add wire clips, and add wire retainer. May run a steel 9 tooth pinion. FCR or Pro track tires
    This is not an expert/novice class; anyone can run in group A or B.
    Any American production plastic body w/ minimum 7 3/8 ” long for Group A (Pony stocks) Group B (Grand National sportsman) cars must be a minimum of 7 7/8”, all cars must be a minimum of 1 7/8”
    high.(no rag top or t-tops) There must be less than 3/8” gap between the tire and wheel well. Group A&B will be scored separate. Plastic bumpers may be scratch built along with grills and headlight covers. Any nerf bars added to the front and rear must not protrude 1/8” past original bumpers. Must have front and rear windows, bumpers. Cars may continue the race if the bumpers are lost, but the windows need to stay in. Body mounting angles may be moved inward for narrow body types. The original body mounts must be re-used, and soldered securely to the chassis.
    Modified stock cars are proposed to run as its own class bi-weekly.
    Modified stock cars may be 4.5” or 4” FCR chassis. Modifications allowed will be: any tires (front tire min .750), any 48 pitch spur or pinion, any guide flag, and any commercially available sealed 16d. (No hardware changes)Any foreign or domestic production body will be legal. There will be no minimum body length in this class. Minimum roof height 1 7/8”. T- tops allowed. No convertibles.
    • Friday 9:00pm GT1/LMP 4”(or open race event)
    Sealed Super 16D motor (Parma or Pro Slot)
    Any Available stamped steel chassis
    Legal Bodies: USRA GT1
    No reversed pans
    48 or 64 pitch gears
    Scale Series rules
    • Saturday 5:00pm Womps 1/32
    Sealed 16D motor or Falcon motor
    2 3/4” max width (THIS INCLUDES THE BODY)
    1/8” Axles only
    no independent fronts
    white nylon flag only
    Parma Corvette, Champion Corvette, Rhino Corvette bodies, Rhino trans am, Camaro, and Mustang. Rhino modifieds, and 1980’s stock car bodies are also legal on a weekly basis.
    • Saturday 6:00 pm Nastruck
    Sealed Parma super 16d
    4.5” commercially available chassis
    JK Nastruck bodies only
    .750 min fronts
    48 or 64 pitch gears, any axles
    • Saturday 7:00pm GT Coupes 4”
    Any non- ultimate (HD) closed cockpit body. Group A cars may use USRA legal GT1 bodies.
    Sealed Parma 501 motors, falcon motors, and Slick 7 Mini motors allowed for group B. Group A cars may use the Proslot sealed 16 d
    Reversed pans are allowed
    • Saturday 8:00pm 4.5” FCR
    Current FCR Pre cut Ford, Chevy, Dodge, and Pontiac NASCAR bodies only. FCR bodies must fit exactly inside a clear FCR body. USRA body rules do not apply in this class. Changes allowed:
    Lead wires, and guide nut may be changed. Wire clips and wire retainers may be added. Front and rear uprights may be reinforced with piano wire or brass tube.
    Steel 9 tooth pinion may be used.
    • Saturday 9:00 pm F1/Indy
    Falcon motors
    Chassis must be JK 1043, 1043f, or any stamped steel chassis
    .625 * .400 fronts
    Legal bodies: JK F1/Indy bodies only
    Chassis modifications allowed.
    Original chassis perimeter must be retained
    The front bushings may be soldered in, or float with music wire “torsion bars”
    Metal materials (brass, stainless, carbon steel) may be added or removed from the chassis, but must stay inside the wheels, and not protrude past the guide tongue.
    Feb 2006
    bolingbrook illinois
    yeaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    i just can't wait to run nastrucks but i di recomend regular 16d motors and no supers? but thats just my opinon
    I'm a sexy beast
