Thread: home made comm cutter/truer
    Oct 2005
    monroe twp nj
    I am planning to make my own home made comm cutter/truer, my funds are limited, that leaves me out from buying one of those ready made ones, so does anyone have any ideas.
    I have afew variable speed electric drills to chuck the arm in, so I can make a mount for it, its the cutting tip and the carriage for the tip to ride on.
    I have lots of materials like brass tubing, music wire, odds and ends of hardware to work with.
    So if anyone out has any ideas, I'll be very greatfull.
    Thanks Orangecrate
    Aug 2005
    I feel your pain. I'm in the same boat. I think that your better off living without one, and sending your arms out every so often. You can have an arm cleaned, re-balanced, stacks ground and re-dyed, and the comm cut for $5.00 an arm plus shipping. They'll even put it in an arm tube before they ship it. There are a bunch of places to send them too, so I just keep watching the boards for a deal, and send them out in the meantime. Just my opinion.
    The ONLY!!!! alternative to buying a dedicated comm lathe is to use a small lathe, like a Sherline or similar, chuck up a ball bearing in a dead center chuck, mount a diamond bit on the tool post, check the runout. The only way you could build your own is if you have access to precision machine tools, and if you gotta buy them it'll cost you a ton more than a comm lathe'
    Accuracy is a must!
    Allow me to amplify on Steve's comments!
    DO NOT chuck the armature in anything if you expect it to actually produce a comm surface that is both round, and more important, concentric to its shaft.
    The basic 'rubber band' lathes used for comm truing are actually very accurate because the arm is located on immobile surfaces. The only way to lose concentricity is for the shaft to be bent or worn.
    Additionally, the typical comm lathe has adjustments for taking up slack in the slides and screws, which allows you to constantly tune it up to avoid chatter. If you buy carefully, these little wonders can be had brand new for under $250 INCLUDING the diamond tip bit. Not cheap, perhaps, but very inexpensive considering the precision involved.
    If you manage to build something but it can't hold concentricity within .0002 or so, you'll do more harm than good.
    Thumbs up $$$ BUT WORTHIT.......
    I know the initial outlay is $$$......BUT how many times do you redo an arm...Do you wait till it really slows? Always complaining your motors are slow....... I have seen where it took more than .015+ to clean a comm!
    I found that after 2-3 races & practice, depending on how soft the comm & how hard the brushes were, I could take up to a .002 cut on a comm and sometimes not get a full clean surface. I took the extra time to take as fine a cut as needed only. I know that it takes much more time but its worth it to me! I am able to get more fast time out of my arms. I would scrape the brushes and still do a water or naptha breakin.
    After 4-5 cuts (8-15 races) I would rebalance those that were balanced before. For ME it paid for itself in less than a year..
    MY $.25 WORTH
    Oct 2005
    monroe twp nj
    Guy's, thanks for the info on the comm truer and save up some $ and buy one.
    Thanks again
    Orangecrate
