Results 1 to 5 of 5
Thread: Parma-Champion chassis fixtures
    Mar 2007
    Michigan
    New redesigned for 2010 Champion Turbo-Flex precision chassis fixture.
    Champion Turbo-Flex precision chassis fixture sets your chassis and guide flag perpendicular to the front and rear axle. No need to remove pans to build chassis.
    Be absolutely sure your car runs straight. Outstanding performance and handling.
    A must have for any serious racers.
    Designed for both 1/8"and 3/32" axles. Has placement for 1/8",3/32"or 1/16 front axle.
    Works for 4" and 4 1/2" chassis.
    Included are 8 stainless steel dowel pins for the axles, 4 steel dowel pins to hold chassis,
    Make your own front axle pins with 1/16 piano wire.
    1 bolt, washer and nut. Measures 3 1/2" x 7 1/4" x 1/2" Corian.
    $31.95 plus shipping $4.95
    Build to Win!! Precision Slot Cars chassis fxtures make racers go faster and win more!
    All designs,products and trademarks are the sole property of Precision Slot Cars! © Copyright 2009
    http://www.pslotcar.com
    Mar 2007
    Michigan
    FCR Chassis fixture
    FCR precision chassis fixture. Designed to hold the chassis and guide flag perpindicular to the rear axle. Works for setting the front axle, an often over looked part of FCR chassis building. Just turn the chassis around in the fixture and you will be able to have a straight and horizontal front axle as well. This will provide improved handling. Use the axle gauge to cut axles to length. Elimates extra weight , works for front axle when stock spacers are retained. Works for both 4" and 4 1/2" FCR chassis. Measures 3 1/2" x 7 1/4" x 1/2" Corian. Patent pending.
    Fixture $28.95 plus $4.95 shipping.
    FCR set up wheel blocks $16.95 plus $2.95 shipping
    Mar 2007
    Michigan
    Flexi 5 chassis fixture
    Flexi-5 precision chassis fixture sets your chassis and guide flag perpendicular to the rear axle. Be absolutely sure your car runs straight. Outstanding performance and handling. A must have for any serious racer. For 1/8" and 3/32" axles. Works without removing the pans. Included are 4 stainless steel dowel pins for the axle, 5 steel dowel pins to hold chassis, 1 bolt, washer and nut. Measures 3 1/2" x 7 1/4" x 1/2" Corian. Patent pending.$28.95 plus shipping $4.95
    Mar 2007
    Michigan
    New information on this chassis fixture. I have been told that it is being used with the original flexi car(flexi 1)
    It just goes to show the only limitations of a Precision Slot Cars chassis fixture is your willingness to experiment
    with pin positions.
    Mar 2007
    Michigan
    Womp-Womp/Thumper chassis fixture
    1/32 scale Womp Womp/Thumper chassis fixture. Make your car straight and square the
    with Precision slot cars chassis fixture.
    Made with Solid material the fixture measures 4" x 6" x 1/2"
    includes 8) 1/8" x 1" stainless steel dowel pins,
    6) 1/8" x 1/2" stainless steel dowel pins
    1) bolt, nut and washer
    $39.95 priority shipping $7.25
    Click image for larger version.
