Results 1 to 2 of 2
Thread: WRP Pro Inline chassis fixture C-02 C-12
    Mar 2007
    Michigan
    The CAD Designed WRP Pro Inline C-02 C-12 chassis fixture is Precision Slot Cars High quality precision build fixture.
    CNC machined for perfect alignment of all the chassis parts in your kit.
    Build with .062 music wire, .072 stainless tube, 078 music wire or .082 stainless tube.
    Use this fixture to build awesome drag chassis's! Hold all parts in the kit square and straight.
    Build like the pros.
    Used by Paul Wilde owner of WRP to build race winning chassis's. Build to win not just compete!
    Adjustable guide bracket adjusts for 12 different wheel bases. Sets front and rear axles.
    Wheelie bar length set at 5.00".
    Complete kit includes:
    One set of set-up wheel blocks,
    one motor box fixture Machined perfectly square drilled and taped to hold all the pieces of the motor box,
    8 hardened stainless steel dowel pins for the axles,
    27 stainless steel dowel pins to hold the chassis parts and main rails,
    1 bolt, washer, and nut.
    CNC machined for precision quality.
    Measures 4" x 12" x 3/4 solid cast material
    The complete kit with 3/32" x 3 5/16" build axle is $99.95 plus shipping.
    Click image for larger version.
    Build to Win!! Precision Slot Cars chassis fxtures make racers go faster and win more!
    All designs,products and trademarks are the sole property of Precision Slot Cars! © Copyright 2009
    http://www.pslotcar.com
    Dec 2003
    Michigan
    Do you make a jig to assemble Koford wing chassis? Something that will put the pin tubes in the exact same places and useable for all the different models.
    Skidmarks
    230 S. Averill
    Flint, Mi 48506
