Results 1 to 3 of 3
Thread: Kentucky Trash Chassis Fixture
    Aug 2009
    Michigan
    The new CAD Designed Kentucky Trash chassis fixture is the newest addition to the Precision Slot Cars family of High quality precision build fixtures. CNC machined for perfect alignment of all the chassis parts in your kit. Build with .062 music wire, .072 stainless tube, 078 music wire or .082 stainless tube. Use this fixture to build awesome drag chassis's! Hold all parts in the kit square and straight. Build like the pros. All pro racers use fixtures and this fixture is the best! Build to win not just compete! 10 possible wheel bases. Sets front and rear axles. Wheelie bar length set at 5". Complete kit includes: One set of set-up wheel blocks, one motor box fixture Machined perfectly square drilled and taped to hold all the pieces of the motor box, 8 hardened stainless steel dowel pins for the axles, 28 stainless steel dowel pins to hold the chassis parts and main rails, 1 bolt, washer, and nut. The 1/2" Corian base of the fixture is hand lapped on a granite surface place. This insures absolute flatness of the build surface. CNC machined for precision quality. Measures 4" x 12" x 1/2" Corian. The complete kit with 3/32" x 3 5/16" build axle is $84.95 plus shipping. (also available in 3/4" thick Corian while supply lasts send a PM for price quote)
    Mrs. Precision Slot Cars
    www.pslotcar.com
    Jan 2009
    Will you sell just the "box" and wheel height block? How tight are the tolerances? I have a set of wheel height deals from another mfg and they are off .004 thou just that short distance between the uprights!
    Mar 2007
    Michigan
    You can purchase any and all fixture components individually from the web site.
    If not listed on the web site yet send me a PM
    Thanks for choosing Precision Slot Cars
    Dave
    www.pslotcar.com
    Build to Win!! Precision Slot Cars chassis fxtures make racers go faster and win more!
    All designs,products and trademarks are the sole property of Precision Slot Cars! © Copyright 2009
    http://www.pslotcar.com
