Hello,
I have one and have had no problems with it. It comes with a jumper plug that, when inserted, gives what they call the "quick charge" feature (~14.2 VDC Output). The output voltage is not variable, it is either ~13.6 or ~14.2 VDC. The only variable output power supply Rivergate has is the RDC-30 VO, Bulldog Variable Output 30 Amp.
See pictures below of the RDC-90:
From Rivergate's Website http://www.rivergatedist.com/
"This is one of the most powerful DC power supplies in the World. Suitable for any application that requires 90 amps @ 13.8 volts
2nd to None if you need more power than this buy a welder.
RF Grounding for Amateur Radio/CB operation.
Modern Design and built Bulldog Tough!
High Efficiency - 90 amps continuous - That's 1200+ watts!
Regulated output {13.8 volts} and short circuit protected.
MSRP: $499.00 You Pay: $405.00
Model RDC-90
Input Voltage 90-135
Input Frequency 40-70 HZ
Output Wattage 1210 Watts
Output Voltage DC 13.6-14.2
Output Amperage 90
Dimensions (Width X Height) 6.75 x 3.5
Length 13"
Weight 8 Lbs.
Fan 2 Thermostatically controlled"
V/R,
Don
50 year pin 1959-2009
