Results 1 to 3 of 3
Thread: JDS Chassis fixtures
    Mar 2007
    Michigan
    The CAD Designed Annihilator chassis fixture, Precision Slot Cars High quality precision build fixture.
    CNC machined for perfect alignment of all the chassis parts in your kit.
    Build with .062 music wire, .072 stainless tube, .078 music wire or.082 stainless tube.
    Use this fixture to build awesome drag chassis's! Hold all parts in the kit square and straight.
    Build like the pros. All pro racers use fixtures and this fixture is the best!
    Build to win not just compete! Adjustable guide bracket adjusts for 12 different wheel bases.
    Sets front and rear axles straight and horizontal to the chassis.
    Wheelie bar length set at 5.00".
    Complete kit includes:
    One set of set-up wheel blocks,
    One motor box fixture Machined perfectly square drilled and taped to hold all the pieces of the motor box
    8 hardened stainless steel dowel pins for the axles,
    24 stainless steel dowel pins to hold the chassis parts and main rails
    1 bolt, washer, and nut.
    3 5/16" long 3/32" build axle
    complete build kit $89.95
    Measures 4" x 12" x 1/2" Corian.
    All Precision Slot Cars build fixtures are available board and pins only $46.95 plus shipping
    Build to Win!! Precision Slot Cars chassis fxtures make racers go faster and win more!
    All designs,products and trademarks are the sole property of Precision Slot Cars! © Copyright 2009
    http://www.pslotcar.com
    Mar 2007
    Michigan
    JDS Revolution C 08
    The new CAD Designed JDS Revolution C 08 chassis fixture is the newest addition to the Precision Slot Cars family of High quality precision build fixtures. CNC machined for perfect alignment of all the chassis parts in your kit. Build with .062 music wire, .072 stainless tube, 078 music wire or .082 stainless tube. Use this fixture to build awesome drag chassis's! Hold all parts in the kit square and straight. Build like the pros. All pro racers use fixtures and this fixture is the best! Build to win not just compete!Exclusive feature of this fixture is the bend point for fabricating perfect tapered frame rails.Adjustable guide bracket adjusts for 12 different wheel bases. Sets front and rear axles. Wheelie bar length set at 5.00" Complete kit includes: One set of set-up wheel blocks, one motor box fixture Machined perfectly square drilled and taped to hold all the pieces of the motor box, 8 hardened stainless steel dowel pins for the axles, 31 stainless steel dowel pins to hold the chassis parts and main rails, 1 bolt, washer, and nut. The 1/2" Corian base of the fixture is hand lapped on a granite surface place. This insures absolute flatness of the build surface. CNC machined for precision quality. Measures 4" x 12" x 1/2" Corian. The complete kit with 3/32" x 3 5/16" build axle is $89.95 plus shipping. (also available in 3/4" thick Corian)
    Mar 2010
    Warren, Michigan
    Revised for 2010 JDS annihilator chassis fixture.
    Multiple wheel bases.
    Wheelie wheel axle posts
    Improved motor box sets upper brace
    http://pslotcar.com Built to Win!
    All designs,products and trademarks are the sole property of Precision Slot Cars™
    All rights reserved © Copyright 2007- 2020
