Page 4 of 4 FirstFirst 1234
Results 46 to 51 of 51
Thread: Is there a chart or guideline to rewinding 1/24 scale slot car motors?
  1. #46
    Sep 2016
    999,000,000,000,000,000 arms to string to the moon and back i think LOL
  2. #47
    By my calculations, I think you are 3 short!
  3. #48
    Sep 2016
    Yeah your probably right. At least three maybe four
  4. #49
    Sep 2016
    here is a link where epoxy coated wire can be purchased . a 10 lb spool for $25 per lb
    http://www.mwswire.com/magnetwire_bondable.html
  5. #50
    Sep 2016
    polymamide epoxy coated wire needs no solvent as a catalyst only heat other types require methyl ethel keytone or alcohol
  6. #51
    Sep 2016
    Quote Originally Posted by wbugenis View Post
    The epoxy Monty Ohren (and other current small scale armature builders) used is from here:
    http://www.cotronics.com/vo/cotr/pdf/4460.pdf
    Not cheap but not horribly expensive and available in small quantities (pints).
    this place sells epoxy coated wire only in 25lb spools http://mwswire.com/magnet-wire/bondable-magnet-wire/
