Results 1 to 7 of 7
Thread: New Product ProSlot Introduces The Velociraptor line of Motors and Parts.
    Land of Excitement "Bensenville"
    Thumbs up New Product ProSlot Introduces The Velociraptor line of Motors and Parts.
    New Products Release
    06/23/2011
    Pro Slot Ltd.
    www.proslot.com
    Official Press Release
    Attention:
    Racers & Track Owners
    During these tough economic times everybody needs to get the most bang for his or her buck. We at Pro Slot understand this and are proud to introduce our new line of economic Neo based motors and parts.
    Introducing:
    The
    “Velociraptor”
    The Velociraptor was designed around our world leading Euro can. The magnets are high grade Neo that matches the shape and thickness of our standard Euro ceramic magnet. They were designed by and manufactured for Pro Slot. This means that ALL of our 4000 series Euro armatures will fit with no changes. This is the most powerful Euro setup currently made. The setups average gauss reading is “1800” putting them on par with G7 cobalt setups. What this means to you the racer is unbelievable torque in a small package.
    PS-4017 Velociraptor “NEO” setup
    This setup has standard .540 airgap and comes with our PS-4011 modified endbell. It accepts any of our Euro armatures. This is the most powerful Euro setup currently made, gaussing 1800 points and producing incredible torque. Add $14.00 for double ball bearings. $35.00
    PS-4018 Velociraptor “NEO” magnets
    They are made to the same dimensions as our OEM Euro ceramic magnet. This means that they install in our standard Euro can with the stock magnet retaining clips and a drop of super glue. No epoxy or special tools needed. $13.95
    Velociraptor “NEO” magnets & Velociraptor “NEO” setup
    Velociraptor “NEO” Complete Motors
    PS-4019 Velociraptor VR 12 “NEO” Motor
    This motor uses the new PS-4017 “NEO” setup with our PS-4012 Euro X-12 armature and includes Goldust brushes. Built for the new wave of “NEO” F/C racing. Our testing using an 85 gram hardbody test car netted .720 ET’s @ 70+ MPH. Recommended starting gear ratio 14/52. Add $14.00 for double ball bearings. $54.95
    PS-4020 Velociraptor VR 20 “NEO” Motor
    This motor uses the new PS-4017 “NEO” setup with a specially made .500 diameter VR20 machine wound armature on our race proven Intruder blank and includes Goldust brushes. This motor was built for the “Serious” bracket racer and would be great for a “NEO” G20 F/C class. Our testing using an 85 gram hardbody test car netted .640 ET’s @ 80+ MPH. Recommended starting gear ratio 14/54. Add $14.00 for double ball bearings. $59.95
    PS-4021 Velociraptor VR eXtreme “NEO” Motor
    This motor uses the new PS-4017 “NEO” setup with a specially made .500 diameter VR eXtreme machine wound armature on our race proven Intruder blank and includes Goldust brushes. This motor was built for the “Ultimate” bracket racer and “Outlaw NEO” class racer. Our testing using an 85 gram hardbody test car netted .590 ET’s @ 90+ MPH. This motor has no equal in performance for the money. Recommended starting gear ratio 14/54. Add $14.00 for double ball bearings. $64.95
    Velociraptor VR “NEO” Motor
    Velociraptor “NEO” Replacement Armatures
    PS-4022 Velociraptor VR 20 “NEO” Replacement Armature
    Machine wound G20 armature .500 diameter, wound on our race proven Intruder blank. This armature is specially sized to fit the PS-4017 “Neo” setup to provide the ideal airgap with no other modification needed. $39.95
    PS-4023 Velociraptor VR eXtreme “NEO” Replacement Armature
    Machine wound, eXtreme wind armature .500 diameter, wound on our race proven Intruder blank. This armature is specially sized to fit the PS-4017 “Neo” setup to provide the ideal airgap with no other modification needed. This is the fastest machine wound armature available for the PS-4017 “NEO” setup. $39.95
    PS-4024 Velociraptor VR Custom “NEO” Armature
    This is a custom hand wound all-out Topgun style armature featuring our EDM commutator, wound on our race proven Intruder blank. This armature comes .500 diameter standard and is also available in .490 & .480 diameters for the custom motor builders as a special order. Standard wind is 25/25, also available: 18/24.5, 15/24, 14/24, 14/23. $58.50
    Michael Mazur
    Ruzam Racing
    Team ProSlot
    Sep 2005
    NO! NO! NO! NOT THAT!!!!
    index
    Aug 2010
    Arizona
    will this work with puppy dog or big dog motors and or arms?
    Quote Originally Posted by EdC View Post
    I think based on this I would think so:
    What are the specs on the VR eXtreme arm? .500" dia, but number of winds, wire size, stack length, and timing?
    Are these mostly for drag racing or do they have scale racing applications as well?? With some of those winds I could use it in my eurosport car or my wingcar...
    Don't think so, too much wire for magnets that strong,look at the air gaps, .40 with .500 arms. These are drag race only. Real neodymium will not take the heat for other racing. If ,as stated, they are equal to cobalt then they are grade24 neodymium iron boron of the weakest commercial grade,they're still good and will work extremely well for drags. And, no, Bill, they will not replace a cobalt euro set up, although the the arms might work in a cobalt setup long enough to fit.
    Aug 2010
    Arizona
    That's what I'm reading Paul...
    "It accepts any of our Euro armatures. This is the most powerful Euro MK1 setup currently made, gaussing 1800 points and producing incredible torque."
    that quote is off proslot.com
Tags for this Thread
