Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
Thread: Choosing a Tire Durometer
    Koria Finland
    There's no point in the absolute figures - a 50 compares to a 45 on another type A (cheap) durometer. But lots of sense to make comparisons, under the same brand of rubber there's a lot of variation, 10 - 20 % easily.
    zipper
    Like many racers who have been around for a while I use the Longacre durometer. I use it for comparison only in an effort to match tires as closely as possible. One thing I learned over the years is that a car will handle better with a matched set of tires and be much more predictable. One thing you should do first is use your tire grinder to get a flat surface. Most tires right out of the tube will be concaved, just like newly in the center, just like newly rubbered hubs, and your readings will be wrong. I always take a surface cut before I duro the tires. Remember that heat and cold affect the tires, I duro mine indoors at around 70 degrees.
    Aug 2010
    Arizona
    Click image for larger version.
Name:	shore selection..jpg
ID:	12510Wouldn't you want to use a gauge that fits the purpose? Such as measuring the softness of a tire under the same load as what the completed car will exert on the tire to track contact patch?
    An "A" scale durometer requires a force up to 822g or 1.81 pounds, our cars usually weigh a little less than that!
    To me after looking at a chart on types of durometer the "oo" scale seems to fit the range for slot cars.
    I will try to upload the scale as it's a great visual!
    Mar 2006
    Sydney, Australia
    I expect my G7 wing car exerts at least that in down force.
    Koria Finland
    G7 measured in a wind tunnel @ 150 km/h did about 150 - 200g afair when measured about 10 years ago.
    zipper
  6. #21
    Aug 2010
    Arizona
    zipperi...
    looks like the type "OO" would be the right type of meter than.
  7. #22
    Koria Finland
    Might be - but I'm quite happy with "A" measurements - between 30 and 50+/100 with current hard tires on .500 to big hubs. Gives a good reference to compare - just must be careful not hitting the holes in the rims.
    zipper
  8. #23
    Jun 2006
    Matched hardness dosent always work best
    Sometimes you run faster with a soft tire on one side and a hard tire on the other side.
    The only real way to know what tire and hardness works best is to test different tire combinations.
    A lot of times when I cant get any tires to work, I try some real off the wall combinations. Sometimes you will stumble on something that really works. Mix and match then...test and retest.
    Support Your Local Raceway !!
    I beat John Cauthen !
  9. #24
    Am I safe in assuming that "softer" (a lower reading on the durometer scale) means better traction?
  10. #25
    Too soft in a banked turn is like a flat tire on a curve - into the fence.
  11. #26
    Quote Originally Posted by Ramcatlarry View Post
    All of our tracks out here in NZ are FLAT
  12. #27
    Mar 2003
    Dallas, Texas
    Dug this one up from the depths of the slot car mortuary
    "Never underestimate the predictability of stupidity"
    Archie King
    2018 TSRA Series Group 7 Champion
    2018 HillBilly Box World Record Holder 1.907
    2016 HillBilly BoxStock Champion
    2014 TSRA Series Group 7 Champion
    Team KOFORD
    http://www.koford.com/slot/
  13. #28
    Moi?
    There's no such thing as a stupid question - only stupid answers
