Results 1 to 13 of 13
Thread: Flat Track Tires
    Flat Track Tires
    From my past experience I've used mostly Gilbert tires. They are fantastic. But I heard great things about Hermanators as well.
    Depending on the normal ISRA type class what overall tire diameter and hub diameter are being raced right now? Does it make a difference if it's 2mm or 3/32s?
    Other than Gilbert and Hermanators, are there any other good choices for tires?
    thanks...
    boise, ID
    some racers around here use ruff cutts, if you can find any now. they are a mid america product
    IDAHO SCC
    dub motors
    herminator tires
    PMP chassis
    Redfox
    BBB
    Aug 2006
    Most everyone around here runs either small hub Speedshop or Hermanator tires on the flat tracks. Tire diameters are dependent on how the car is jigged. I haven't noticed any handling differences between cars jigged with 40 tooth spurs or 42 tooth spurs with otherwise similar setups. I have cars that need .685s to make a whole race and others that only need .665s to make the whole race and have been successful with both. Sometimes, you jig the cars you race later in the day with the smallest spur so you can recycle tires from earlier in the day....
    In the 1/24th scale cars (Group 10 all the way through Open 12), most are using 3/32 axles, however, there were a few that were running 2mm at one time. For ES24, certain people swear by 2mm, others stay with 3/32. For ES32, most everyone is running 2mm.
    ___________________
    Check us out.
    The Race Place
    1151 Highway 33
    Farmingdale, NJ 07727
    732-938-5215
    Jan 2006
    Nor Cal
    Quote Originally Posted by palm_dog View Post
    I'm pretty sure that Frank at Slotcar Raceway has them, along with Hermanators and many more . Give him a call!
    www.scrhobbies.com
    that's a wrap!
    Pretty much what Jerry said with the sizes.
    Speedshop, Hermanators, and MA Roughcuts for rubber. I've had some recent success with Kelly's as well. Depends on the track that day.
    I have some Roughcuts if anyone is having trouble getting them.
    I tried Ruff Cuts in the weekend and they started pushing into the centre of the rim (tyre coming loose) - anyone else experienced that?
    These are rim/tyre combo not donuts I have mounted myself
    PM sent
    Mar 2009
    Everett, Wa.
    Zip:
    I see a new tag line, that;s so not PC!! I love it!
    Guy Middleton
    Everything I was taught in Engineering school I had already learned from slot cars....
    Quote Originally Posted by MentalKase View Post
    Zip:
    I can thank Butch for it
    Dec 2005
    England
    You can try some BSP's. ALot of guys ran them at the worlds under different names....
    A box of Hermanator Donuts arrived today I will run a pair up tonight and try them on Weds.
    Sent from my iPhone using Tapatalk
    Are they grayish or black in color? Are the pores really small?
    Flat Track Tires
    black, fine pores, one smooth end
