Results 1 to 15 of 20
Thread: 50 Amp Variable Power Supply
    Dec 2011
    Independence, MO
    Has anyone used this 50 amp variable power supply?
    TekPower TP50SW 50 Amp 13.8V Analog DC Power Supply with Cigarette Plug
    It appears to be the same as the one listed in the OWH shop at a very cheap price. Wondering if it is too cheap for a small commercial track.
    This would be used in a 6 lane 1/24 oval track.
    Another option would be the VOLTEQ Power Supply HY1550EX at a much higher cost that was recommended by Swiss.
    Mark
    Feb 2014
    KC. MO.
    This looks like it would work fine..I like the adjustable power supply feature 9-15Vdc. ...This looks like what you have pictured only a different name...$160 + $13 shipping.
    Regulated 50 Amp Compact Power Supply 13.8Vdc (9-15V Adj) w/ Volt - Amp Meter!
    Kotka / Finland
    We are using HP DPS 600PB 47A power supply for rental cars. It is quite easy to modificate power supply to give voltages between 10-13.8V. Modification needs only two resistors and one potentiometer. Resistors are used to limit minimum and maximum voltage. We have also added two 50A diodes to drop output voltage to about 9V. Power supplies are available from ebay. These cost about $20.
    More info about modification:
    http://www.rcgroups.com/forums/showp...&postcount=586
    Headed for the beach
    I've used that power supply for my mobile tracks. Works ok but just cant believe it's a 50 amp. Hard to tell since I use Plafit Rabbit motors (very low amp draw).
    Kotka / Finland
    It is possible to use two DPS 600PB power supplies in parallel. Server power supplies have current share signal which is used to connect powers together. I havent't tested it on DPS 600PB. We are using CS-signal with AHF-2DC-2100W power supplies which are our main power supplies. Two power supplies can supply 350A. These have also voltage sensing circuit but power supplies doesn't have -5V voltage which needed output voltages below 12.1V. AHF-2DC-2100W max voltage is 14.1V. We are using 12.5V in our scale track. Picture from testing power supplies in parallel.
    http://pyrtsy.kapsi.fi/kopsa/index.p...082790321595_o
    Dec 2011
    Independence, MO
    Quote Originally Posted by tpahula View Post
    This is interesting. It will be fun to dig into this and see how you use the resistors and the diodes. Since it is not my track the owner may wish to just buy something.
    Mark
    Dec 2011
    Independence, MO
    Quote Originally Posted by CruzinBob View Post
    I also have my doubts about the quality of the power supply which is why I asked. Woodman (who posted above) had a very nice pyramid on a small track but it was only about 20 amps. The next size pyramid is 30 but it won't adjust below 12v.
    Mark
    Dec 2011
    Independence, MO
    Can you clarify what size potentiometer and resistors are required to limit voltage and how they are installed?
    Mark
    Feb 2014
    KC. MO.
    Cheap and easy Adjustable Voltage....the voltage adjustment through the diode rotary switch described here
    http://www.philippejmarchand.com/Slo...58/page58.html
    Dec 2011
    Independence, MO
    Quote Originally Posted by woodman View Post
    I built a couple of those for brake adjustment before I bought my Difalco's. Terry would like to be able to control all lanes with one control. Apparently a 1k Pot can adjust the server power supply.
    Mark
    Kotka / Finland
    I have to check actual resistor values because I tested several different resistor values. We are using 2k pot. We are using 270ohm and 300 ohm resistors if I remember correctly. Resistors are in between outer legs of potentiometer and pins 3 and 5. Potentiometer wiper is connected to pin 9.
    Power will shut down if resistor values are too small. I made small drawing about connections.
    Click image for larger version.
    Dec 2011
    Independence, MO
    Perfect.
    Mark
    Dec 2011
    Independence, MO
    Just got a DPS 600PB off ebay for $14 delivered. I also ordered: 2k pot, two 500k trimmer pots in lieu of resistors, five JR extension cables for pinouts and a LED voltmeter.
    Total $19.26. If it works it is an absolute bargain. If it doesn't it was $20 worth of fun.
    Mark
    Dec 2011
    Independence, MO
    What type of 50A diode did you use? The only 50A diodes I found are bridge rectifier type with 4 legs? or Blocking diode?
    http://www.ebay.com/itm/Bridge-Recti...item3f24fedcf3
    http://www.ebay.com/itm/50A-1000V-BL...item19e6dee9f1
    Mark
    Kotka / Finland
    We are using ESM 243400 diodes. It is actually 60A diode.
    http://electols.com/index.php?main_p...ducts_id=72857
    These are old diodes. We are attached diodes to old PC processor heat sink.
    This diode could be used in lower voltage:
    http://www.newark.com/vishay-semicon...3ab/dp/09F2902
    Also blocking diode should work. Threshold voltage of diode is used to lower output voltage.
