Results 1 to 12 of 12
Thread: Omni brakes
    Nov 2015
    Omni brakes
    Hello all,
    I recently got an omni controller, and now seem to be having brake issues. I used the controller one night in our gtp race and practice and it worked great. The next race night it seemed like the brakes were intermittent. It's now to the point where there is no difference with the brake full on or off. Is there anything I can do at home to test the switch? I do have multimeters and access to a power supply if needed.
    Is the trigger returning fully to activate the brake contact? Is the contact dirty?
    Nov 2015
    Yes, the trigger does return fully to the brake contact.
    Sent from my SM-G925P using Tapatalk
    Jun 2013
    Orange County, California
    Look at the brake fuse , if any. Use a meter to test the fuse. Look at the solder connection on the board and the alligator clip. Check the wire to see if it is broken in the insulation.
    I am not familiar with the Omni controller but the brake quitting is not normal. What the brake pot? Is it a linear pot or a diode switch? Check the value of the brake switch/pot.
    John Andersen
    DR Racing Products
    Nov 2015
    I don't see any fuses on the controller. The connections and overall wire condition looks okay. The only place I could not really tell is where the red wire is spliced and has shrink tubing over it.
    Jun 2006
    I used one of these for years. When I hooked it up backwards by mistake, the brake switch would get fried and I would not have any brake no matter the switch position.
    Sounds like you need a new brake switch.
    Support Your Local Raceway !!
    I beat John Cauthen !
    Homeless in Canada
    Test the switch. I would try that first.
    Nov 2015
    How would i go about testing the switch?
    You can eliminate the switch from the circuit by jumpering between the blue and red wires on the Omni board. Doing this should give you full brakes and confirm that contacts and wiring are not to blame for your problems. If you have brakes then the switch would be the next item to change out. One thing you might also try is to move the switch between its settings repeatedly (5 - 10 times) quickly to perhaps clean off contacts in the switch that may be corroded or arc'ed up in the switch.
    Ramcat larry works on Omni's.
    Nov 2015
    Thanks for the replies all, i have been incontact with Larry and plan on sending the controller to him.
    Top position of the slide switch should be FULL brakes and the bottom, NO brakes. Middle positions are different partial brakes.
