Thread: Info on Bent Axles
    Jan 2007
    arkansas
    Info on Bent Axles
    How do tell if your axle is bent
    sirlard1954
    Roll it on a piece of flat glass
    Koria Finland
    I check them against light on my Mauser which is dead straight. A dial indicator is more professional.
    zipper
    To expand on Zippity's use of glass. slightly incline the glass when you roll. Any slight bend in the axle will make a distinct noise as it rolls. As zipper says, a dial indicator with "vee" blocks looks more professional.
    Don't mistake a bent axle for a bent rim or a rim/axle combo that has a sloppy fit. I have come across axles that had a diameter that was too small and rims that had bores too large. The effect was like a bent axle and they would chatter. You want a nice snug fit between the axle and rim. Also keep in mind that not all rims are created equal some have a very generous run out. I check all the tires I buy using a known straight axle in an old chassis I installed bearings in, it works really good for me and allows me the convenience of pairing up the rims with the least amount of run out for racing and the rims with the most run out for practice.
    If it is still on the car and the car bounces on its own, then a wheel or axle is bent. If a drill blank is not used for a rear axle, it is bent. M2 drill blanks flex better than M7 - they break instead of bend.
