Thread: Gears
    Jan 2007
    arkansas
    Gears
    What would cause 4 spur gears to be stripped in just a few laps
    sirlard1954
    Many things: loose motor, way too much gear lash, 64 pinion with a 72 spur or vice versa, very loose axle bearing or oilite would be the first things to check.
    Hope this helps.
    Australia
    Or a cracked chassis which is more likely to happen in a spring steel chassis
    May 2002
    Also check for play in the can bearing and armature shaft.
    Bill Taylor
    HiSpeed Products
    www.hispeedproducts.com
    Gear teeth may not be parallel or at an angle. No matter what pitch gears you use remember that the gear teeth must be parallel to each other. If they aren't the steel pinion will eat away at the plastic spur gear. No matter what combo of gears you use straight spur straight pinion, straight spur angled pinion, angled spur straight pinion or angled spur angled pinion the teeth must be parallel to each other. It also helps very much if the axle and motor armature shaft centerline are on the same plane.
    Jul 2002
    Madera, CA
    Have you solved your gear problems??? If not send me a messenger thing.. or email, and I'll try and help..
    fbhood@comcast.net
    If you're serious about Slotcars get Cars By Crash
