Page 3 of 3 FirstFirst 123
Results 31 to 44 of 44
Thread: Multi Magnet Motors
  1. #31
    Page 3 works for me. It is page 4 that sucks!!
  2. #32
    Koria Finland
    You mean page 2 - it still shows blank (perhaps after a brief flash, probably attempting to load something). Page 3 is ok.
    zipper
  3. #33
    Koria Finland
    W3c complains about page 2:
    Warning Line 90, Column 77: cannot generate system identifier for general entity "s" …read.php?42683-Multi-Magnet-Motors/page2&" />
    An entity reference was found in the document, but there is no reference by that name defined. Often this is caused by misspelling the reference name, unencoded ampersands, or by leaving off the trailing semicolon (. The most common cause of this error is unencoded ampersands in URLs as described by the WDG in "Ampersands in URLs".
    Entity references start with an ampersand (&) and end with a semicolon (. If you want to use a literal ampersand in your document you must encode it as "&" (even inside URLs!). Be careful to end entity references with a semicolon or your entity reference may get interpreted in connection with the following text. Also keep in mind that named entity references are case-sensitive; &Aelig; and æ are different characters.
    If this error appears in some markup generated by PHP's session handling code, this article has explanations and solutions to your problem.
    Note that in most documents, errors related to entity references will trigger up to 5 separate messages from the Validator. Usually these will all disappear when the original problem is fixed.
    Error Line 90, Column 77: general entity "s" not defined and no default entity …read.php?42683-Multi-Magnet-Motors/page2&" />
    This is usually a cascading error caused by a an undefined entity reference or use of an unencoded ampersand (&) in an URL or body text. See the previous message for further details.
    Warning Line 90, Column 78: reference not terminated by REFC delimiter …read.php?42683-Multi-Magnet-Motors/page2&" />
    If you meant to include an entity that starts with "&", then you should terminate it with ";". Another reason for this error message is that you inadvertently created an entity by failing to escape an "&" character just before this text.
    Warning Line 90, Column 78: reference to external entity in attribute value …read.php?42683-Multi-Magnet-Motors/page2&" />
    This is generally the sign of an ampersand that was not properly escaped for inclusion in an attribute, in a href for example. You will need to escape all instances of '&' into '&'.
    Error Line 90, Column 78: reference to entity "s" for which no system identifier could be generated …read.php?42683-Multi-Magnet-Motors/page2&" />
    Info Line 90, Column 76: entity was defined here …read.php?42683-Multi-Magnet-Motors/page2&" />
    Then it finds 22 errors and 12 warnings in total on the site.
    zipper
  4. #34
    Quote Originally Posted by zipperi View Post
    Set your number of posts to show per page to 5 in thread display options, under General Settings, My Account, My Settings, and see what happens
  5. #35
    Koria Finland
    So the fault lies in posts 16 - 20. Using 40 posts per page doesn't load at all.
    zipper
  6. #36
    Correct!!
  7. #37
    Australia
    How do I insert a image ?
  8. #38
    Quote Originally Posted by Ron View Post
    Read this
  9. #39
    Australia
    S16D Rules
    Here are the S16D rules for Hornsby Slot Cars.
    It says magnets to be original for a D can setup
  10. #40
    As far as I can tell, 16-30.
  11. #41
    Quote Originally Posted by swiss View Post
    Using 5 posts per page, I have narrowed the fault down to between 16 and 20
  12. #42
    Agreed.
    At 5 posts per page, page 4, or 16-20.
  13. #43
    Koria Finland
    What about the invalid attachment on post #18 - Ron, could you check/remove it?
    zipper
  14. #44
    Australia
    John Miller talks about Proslot Quad D can magnets
