Results 1 to 15 of 20
Thread: RM Arrow Flexi Chassis
    Has anyone tried one of these yet?
    https://www.ebay.com/itm/RM-1314-4-A...ss!11501!US!-1
    Don't resist....VOTE !
    The pan cannot be removed without removing lead wires first.
    They could have put a bit more effort into the design IMO.
    It looks like the pan will come out with the guide wires in place if you unscrew the guide flag. Some other chassis that I used to use was like that. (Champion Turboflex or Astroflex maybe, I don't remember.)
    Jan 2008
    mechanicsville Virginia
    If it's nice flat steel I'd give it a go. But the front wheel supports look too wide...wheels wouldn't fit if you wanted them to.
    Anything worth doing is worth overdoing
    Quote Originally Posted by dlatch View Post
    I think those are body mounts. Two spaced the same in the rear.
    Jan 2008
    OMG...you're right. Geeze...if you used all eight your body be goin nowhere! Who's making them?
    I think the alternate body mounting points work with different classes. GTP would be pintubes as far apart as possible to leverage the body aero. I am sure one or more set of holes will fit body clips.
    Many classes do not use front wheels - only stickers.
    I might make a GTP/Phoenix for our monthly races.
    Apr 2012
    Great chassis, very smooth.... easy to set up as well, used red fox bodies in the testing....also an Outasight cadillac as well as a Sunset Ferrari and a Porsche 917... all within a few hundreds of each other....
    CK DaBoer
    Knocked you out of the slot!
    It also can be had with an aluminum pan or a pan for Tri-oval racing only. I have one with steel pans and I bought an aluminum pan to try it out. My center section was dead flat but both pans needed attention to get flat. I saw it raced at the Flexi Flats and it did well.
    Thanks guys. I'm going to order one from World Famous Port Jeff Raceway.
    Mar 2015
    So, the term " stamped steel chassis " is no longer valid for flexi classes ? ..... these chassis appear to be laser cut .... am I wrong ?
    Formed metal from sheet stock is more accurate. With modern CNC laser or other cutting methods, no tooling cost is involved - only program and design. Design changes and updates can be implemented in each batch cut.
    It's still a stamped out or formed steel chassis. Opposed to a spring steel chassis like a Eurosport or GT-12 car. As Larry said, cutting the blanks by laser reduces tooling costs. Have you ever seen a chassis punched out towards the end of a tools production life?
    C11 comes to mind. Never did see a flat one
    The last C11 chassis I bought was the flattest I ever got. Pan was flat and so was the center section. I never built it because it was superseded by the X25. Now all the earlier JK chassis I have are outdated by the C43 and the new Mossetti chassis. Very sad, a lot of wasted money, their all in the retired bin with the Cheetah 1s, Racer Products, Astros, T-Flexs, Trinitys, and a good selection of Parma Flexis. I'm now a two chassis racer unless the RM proves to be better, the agony continues.
