Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 68
Thread: Help!!!!
  1. #46
    Talking Hope Your Other Half.....
    Wasn't looking over you shoulder...... JOU GOT SUM SLANNIN TO DO....... As Desi would say to Lucy..........
  2. #47
    Lake Saint Louis, MO
    Update
    Hey Vic,
    I make a mean eggplant parmagianna...and most anything else that goes with a nice red. But when you're done explaining your proposal to Jeannie, would you explain it to Mary Ann as well?
    I started work on the controller mount this weekend, constructed from 1/2" thick oak, 8-32 bolts and some 1" long nylon spacers I found at the local ACE Hardware.
    The oak was first cut into 3-1/2" x 4" rectangles and bolted together with the spacers.
    Controller Pics 001
    Controller Pics 003
    I then realized that one of the pieces needed to be trimmed for the sensitivity adjustment knobs.
    Controller Pics 006
    So far so good but it appeared that some wood could be trimmed back from the trigger area for Joe's comfort...so out came the saw again. No guys...I don't wear red fingernail polish. Mary Ann makes a damn fine Tool Time Girl!
    Controller Pics 007
    She also takes better photos!
    Controller Pics 008
    When we were done, it looked like this.
    Controller Pics 009
    Controller Pics 010
    All that's left is to mount the controller board to the wood with standoffs and drill holes for the PVC pipe. Now that I've a better idea of the standoff dimensions, I'll see if Newark or ACE Hardware has any stock items. If not, I'll take Wing-Car Nut up on his offer to machine some custom ones for us.
    JayGee Racing Controllers - 24 Bands of Bliss
    www.jaygeeracing.com
  3. #48
    Sorry Mary Ann, Its just that guys like us are so hard to find !! Just ask Jennie, NOT !!! HEHEHE Wow Jeff, looking good. I was just showing joe the pics. Hes so happy !! Thank Mary Ann for her help too. Joint effort ?? If you guys need anything, give me a call.
    Thanks Jeff, you to Mary Ann
    Vic/Joe+Jennie
  4. #49
    Standoff Specs
    Wing-Car Nut,
    I emailed you the specs tonight, along with my office address at work.
    Thanks,
    Jeff
  5. #50
    Joe's Controller
    Wing Car Nut was kind enough to make these 1/4" high standoffs for this project.
    Controller Pics 024
    They were sized perfectly to fit inside the controller frame's mounting holes.
    Controller Pics 026
    And threaded to accept 6-32 machine screws.
    Controller Pics 022
    The standoff's shank was made about 15 thou shorter than the thickness of the frame's PCB. When the screw is tightened, the board is clamped tight to the standoff by a #6 washer.
    Controller Pics 019
    The mounting holes for the frame were drilled first...locating it in the frame so that as much of the trigger poked out of the bottom while still leaving enough room to give one access to the throttle and brake adjustment knobs.
    Controller Pics 018
    Controller Pics 017
    A 1" hole saw was then used to make the mounting holes for 3/4" ID PVC pipe. The holes were opened up slightly with a dremel because the pipe's OD was just slightly larger than 1". The holes were located so that the pipe's elbow could point either upward in this pic or to the right without blocking access to the adjustment knobs. A matching hole was then drilled in the other side of the fixture.
    The elbows were press-fit into the fixture and mounted to the PVC frame.
    Controller Pics 015
    Here's a couple of pics of the controller mounted to the chest plate.
    Controller Pics 013
    Controller Pics 011
    And Joe's eye view of his JayGee Linear 200.
    Controller Pics 012
    The first track testing will take place this Saturday at Mid-America Raceway.
  6. #51
    Thumbs up Lookin Good.......
    WOW... Its really coming together nicely........BEST YET...
  7. #52
    Tickets
    About all that's left to do is convince my employer to pay for my airline tickets to Boston so I can fit the controller to Joe. I figure that no matter how well I plan they'll need to be some on-site adjustments to be made.
    Jeff
  8. #53
    Sep 2005
    Windy
    Hm, or fly Joe to Chicago?
    ‎‎"Your work is going to fill a large part of your life, and the only way to be truly satisfied is to do what you believe is great work. And the only way to do great work is to love what you do." - Steve Jobs 1955-2011
  9. #54
    Success!!!!!!!!!!!!!
    Hey Vic,
    Tell Joe I took laps with the worlds first chin operated controller on Mid-America Raceway's Midwest Monster tonight. Pics to follow later.
    -Jeff
  10. #55
    Mar 2004
    Cool!!!!
    Jeff, If I ever have the bucks to buy a real nice controller it'll be your's without question!!
    All these people working together to help this boy out is something you all should be very proud of!! Maybe I can build him a car or something, it's not much but it's something.. Vic, what kind of cars do you guys like to run?
    SS
  11. #56
    Quote Originally Posted by Southslot
    SS
    THANKS, Joe loves 41/2 stock cars, They are what him and I used to run a few years back. He also liked good old fashion flexi cars.
  12. #57
    Mar 2004
    Vic
    Check your PM's. Looking forward to an update on Joe today.
    SS
  13. #58
    Because someone is going to kick my A$$ cause it is 1:30 in the morning
    If you can't get them to spring
    Quote Originally Posted by JayGee
    Jeff
    I will give you the miles.
    Later
    Tony
    Geez cry a little louder so EVERYONE knows just what kind of woman you are!!!
  14. #59
    Joe's controller in action
    O'k, Mary Ann is much prettier to look at than I do and had volunteered to model the controller, but she does take better photos. So you get to see my ugly mug instead.
    Vic, let me know if Joe is huskier than I am around his chest. If so, we'll have to be prepared to lengthen the belt that holds the chest plate on. Since the PVC pipes are just press fit together, it'll be easy to move the controller fixture up/down and backward/forward for Joe's comfort.
    Controller Pics 027
    You can clearly see the USB cable in these photos. The power module is resting on the drivers panel.
    Controller Pics 029
    For those of you that keep track of stats, I managed to get my ISRA B-Production car around the track in about 10 seconds...about twice as long as it normally takes me. Ummmmm, I wonder if I can claim a track record for chin operated controllers?
    Controller Pics 031
  15. #60
    Thumbs up so cooooooool
    Jeff, Im going to take the lap top back into joe this morning. Hes got to see this !! All your hard work is paying off. I,ll post more info on joe tonight.
    Vic
