I went back read thread. I did not see where you posted the cars/motors you will be running. Check out this link. It will show power drop over distance for a given gage wire. I used 12gs stranded for lane distribution and 8ga from power supply to main power taps, ~4ft, on relay board for each lane to pull power from. We run up to GR12 and never have a problem. My power tap runs are ~25ft. Remember that the smallest link in the system dictates the strength. So if you are going to use the normal 50/30 or 40/30 amp relays most people use, the conductor through these is relatively small. Because it is also short it can carry a pretty good load. I think you might be going a bit heavy for main power supply to relay board but I guess better safe than sorry.
Raymond knows what he is talking about and I am sure he is lurking around here somewhere. He can answer this with authority.
